Hi
Im looking for a very quiet, fully modular PSU - in the 500-600w range. I was looking at the Seasonic fanless ones but then realised that it wouldn't work in a prodigy.
Does the prodigy have vents in the bottom? - so you could mount the psu so the vents are facing to the bottom of the case so the heat is dissipated straight out.
The seasonic fanless relies purely on convection and since heat rises turning it upside down wouldnt be good (my old physics teacher would kill me for saying heat rises!)
