Hi Guy's,
This issue is rather odd and i could do with some advice!
basically when i restart my computer the system posts but the graphics card does not display anything, it's just a black screen. I didn't realise at first because my speakers were low, but you hear the vista login sound. This issue only happens with a restart, if i shut down and cold boot everything works fine.
In order to get it to work again from a restart i literally have to hard reset my comp from the mains, pressing the reset button doesn't work.
my system is running totally stable @ 3.4ghz my specs are as follows.
C2D 6420
asus pk5 deluxe
x-fi
sapphire 4870
74gb raptor
i initially thought it was a stability issue with my OC on my comp but it appears not to be the case, tested the memory with memtest before i realised the system was posting into vista.
Interesting the issue seems to go away when i run at stock settings on my cpu?!?! i can restart with no issues.
The issue was sporadic but appears to have got worse over the past week.
i've updated my mobo bios but still the same issue.
Any ideas?
Thanks in advance
cheers
C2D 6420
asus pk5 deluxe
x-fi
sapphire 4870
74gb raptor
Any ideas?
Thanks in advance
cheers
