Very Strange firefox - Help!
14 Apr 2004
UK
I was just browsing then I just closed the browser opened it up again and noticed the following went missing:
> Search Engines in the search box
> All my bookmarks below my categorised folders, roughly about 50
> Customized tabs on UI bar
How did it occur and more importantly, can I get the bookmarls back? :confused:
radikal_dj said:
Maybe you could try a system restore? - Other than that - do a search for bookmarks.html from Start>Search.
Didn't work, the bookmarks are just displaying the one's listed but bless bookmarkbackups which I didn't realise I had installed. It made a back up of it :cool:
Now off to find the important search engines that I had :(
Guys, I've got a really strange problem, the engines aren't adding at all and I cant add bookmarks. Also when I customize and close FF then re-open it, all my customization disappears :confused:
It's just b0rked out the blue :\
Any Ideas?
p.s I updated to latest version
EXACTLY the same thing happened to me (about two weeks ago). couldn't find any way of solving it. i actually resorted to using IE for a while until i did a HD format, and now everything is fine.
