Ok so I just upgraded my PSU and GPU (to this and this respectively)
With the GTX460 plugged into the system, everything appears to boot normally and I get the Windows 7 loading screen (with the little circling colour blobs) but as soon as I get to the desktop the screen only displays a thin, horizontal strip across the top. The rest of the screen is black.
I can see the top of the Recycle Bin icon, and can move my mouse cursor up into the little gap, and right click to get the desktop menu, etc. but the rest of the screen is still black.
Just to clarify: I can see full screen display fine as Win is booting, but as soon as I reach the desktop I can only see a thin strip at the top.
The GPU's fans are both spinning and both 6 pin PCI-E cables from the PSU are plugged in, so it seems to have power.
I've now swapped back to my Sapphire HD 2600XT card, uninstalled the drivers, and retried the GTX460 but I'm still getting the same issue. Tried a different monitor, same.
My mobo only has one PCI-e slot, so I'm unable to try a different one.
Mobo is: Gigabyte GA-P35-DS3L iP35
CPU: Intel Core 2 Duo E4300
RAM: 4x Kingston 1GB DDR2 667MHz
Anyone have any idea what's going on??
