- 28 Jun 2005
- Behind you
Ello Guys,
I have a really strange problem. I can't go to Microsoft MSDN sites such as http://msdn2.microsoft.com/en-us/xna/default.aspx as all I get is the waiting for reply message in the status bar. Happens in both IE and FF. The funny thing is that it works on my brothers PC which is on the same router. All other sites are fine so I think maybe its VS2008 Express I installed as that wont connect to online help. Any ideas?
Thanks
Thanks
