- 29 Mar 2011
Hi all, Just joined up
Apologies up front for a rather long first post!
Whilst not at all new to PC's (having worked on them for quite a number of years now) I am becoming baffled by this one:
Asus M4A78LT-M board.
AMD Phenom II x6 1090T BE CPU (3.2Ghz)
4x Elixir 2Gb DDR3 RAM - M2Y2G56CB8HC5N-CG (8Gb total)
Everything is stock standard.
CPU = stock 3.2Ghz
RAM = 1333 1.5v
Now here's the problem:
With 2x 2Gb sticks installed in A1 + B1 slots, everything is hunky dory.
With all 4 sticks installed, I don't even get a POST beep.
Absolutely nothing...black screen.
If I mess around with some settings, I can get it to run with all 4 sticks.
I tried adjusting the memory voltage up to 1.56, 1.59, etc.
I attempted to add a 9-9-9-24 timing, although the mobo's BIOS is fantastic for tweaking - dozens and dozens of settings, a lot of which (for memory) I cannot find the correct settings for. So just added the usual 9-9-9-24 timings and left the rest of the options on auto.
I have tried running the RAM at lower clock speeds - it runs fine.
I have tried higher (800) but it won't run.
So, it's usually left at 667.
Eventually, I have it running on all 4 sticks.
It will run all day.
I can run Phoronix benchmarking suite all day, through the various tests.
I can run Memtest+ perfectly well.
It will reboot fine, over and over.
However, if left off overnight, I can return to it in the morning and we're back to square one!
No POST. No nice Beep!
If it remove 2 sticks, going back to just A1 + B1 slots again, all is well.
The configs are still held in the BIOS from before.
I drop everything back to "auto"
Reboot.
Start applying changes again.
Add the other 2 sticks and eventually have it working again.
This can sometimes take quite a few attempts but it gets there in the end.
Untill it's left overnight, turned off, again.
(By turned off, I just mean simply powered down in the usual manner. PSU still plugged into mains supply, etc)
Bear in mind, it is *not* losing my BIOS tweaks. They are still present the following day.
I cannot seem to find much info on the RAM sticks - correct timings, etc.
A full set of timings/settings for these sticks would be wonderful.
If anyone can offer any insight into this, or any kind of advice, suggestions, all will be very gratefully received!!
Many thanks
CPU = stock 3.2Ghz
RAM = 1333 1.5v
Reboot.
Many thanks
