I've just moved my server from the small case it was in before into a larger one due to running out of space for drives, anyway the rebuild went without issue that was until i booted up apon doing so i was greeted with a black screen so i restarted and the same so powered down and checked everything and all the leads and connections were in place so thought the psu was to blame so removed the one out of the other case that worked perfect for well over a year and got the same result retried a couple of times and nothing so removed ram ect and reseated no change so decided to reset the bios and it fired up
...... but after resetting the time and all the other bits in the bios saved and exited and got a blue screen no message or anything as its still in the bios so reset it and got a black screen so i waited to see if anything changed and nothing..... so by this time i was getting a little ****ed off so reset the bios and instead of entering the bios i just f1 to continue and it works the only problem is if the power go's off ext or windows decides to install updates and reboot i get the same old black screen
now before i get onto spec i did and still do have a problem when i first start the pc it don't pick up the hdd's or sometimes 1 or 2 of them i don't know if it's all part of the same fault or not just thought i would say and hey may as well, hopefully a fix may come up
right the spec:
athlon x2 3600+ stock with sunbeam cc something or other well over kill and temps are low around 20-30'c
Abit AN-M2HD
ocz 800MHz 2Gb
psu std 500w removed from a pc of higher spec and power requirements and run perfect
HDD's 3 1.5Tb Samsung f2's + 1 750Gb f1
and that's about it apart from 1x 120mm fan
any help would be most appreciated
............ but after resetting the time and all the other bits in the bios saved and exited and got a blue screen no message or anything as its still in the bios so reset it and got a black screen so i waited to see if anything changed and nothing..... so by this time i was getting a little ****ed off so reset the bios and instead of entering the bios i just f1 to continue and it works the only problem is if the power go's off ext or windows decides to install updates and reboot i get the same old black screen
right the spec:
Abit AN-M2HD
ocz 800MHz 2Gb
