9 Jul 2008 at 21:54 #1 wesley wesley Soldato Joined 29 Jul 2003 Posts 7,701 using google earth, when click a picture, it open IE, how to change the setting so i can open firefox instead? i remmy years ago there was a way do this in control panel but cant find it cheers edit: XP SP2
9 Jul 2008 at 21:57 #2 daven1986 daven1986 Soldato Joined 29 Oct 2005 Posts 3,298 change your default browser to firefox. it is in the start menu properties, if i remember correctly.
9 Jul 2008 at 22:12 #4 bledd bledd Don Joined 21 Oct 2002 Posts 46,888 Location Parts Unknown in FF, tools, options, advanced
9 Jul 2008 at 22:17 #5 daven1986 daven1986 Soldato Joined 29 Oct 2005 Posts 3,298 ah yes, my bad. i was thinking about showing it on the start menu instead of IE! also you need to disable the default browser check in IE
