- 14 Jun 2004
- Newcastle U/T
Well after seeing the LL v350 Im Very tempted to move over to SFF.
Was originally lookin at gettin a Q6600, now changed to an e8500.
will a SFF case be within decent temps to OC this type ov chip a fair way? My understanding is they run cooler than Quads anyway.
if So what cooler is the best to pop into either the v350 or possibly the Sugo.
Is there enough clearance behind the front intakes to mount a swiftech H20 120compact if the coolers that will fit wont keep up with an Overclock?
Lookin at pairing 4Gb RAM, 4870, E8500 which of the current mATX mobo is most suitable/reliable for this keeping in mind the overclock, I would like to be able to take the 8500 as high as possible.
Is there anything else I need to know about these cases?
e.g cooler x wont fit, PSUs longer than x wont fit, anything really.
I'm guessing limited space a modular PSu is a must.
Also decent onboard sound would be Ideal.
