- 4 Dec 2008
Hey,
Been getting BSoDs recently with this new build, usually 0x0A, 0x1E, 0x7E or 0x124 or just a hard reset under load. Thought it was a bad OC, reverted the OC today (it was only a slight one) - no joy, if anything the system is less stable.
It's now taken to rebooting whenever it damn well feels like it (hard locked 3 times tonight while browsing) and cutting PCI devices off (WiFi and sound stop working at random), as well as losing USB devices at total random. Typing from the machine now just about, ready for it to go at any minute.
At first I thought I'd fixed it by uninstalling disconnected devices from device manager, but the moment I reinstalled the graphics drivers I got a BSoD and no POST. Made me think it was graphics card but could a graphics card do all this weird stuff?
-No thermal issues
-Cleared CMOS countless times
-First time it hard locked while browsing I smelt a slight burning smell; last time this happened was when ACC was enabled by accident and it's worked fine (mostly -.-) since this
-Set volts manually and messed around with BIOS settings
-Prime 95'd, Memtested and ATiTool artifact scanner'd, no dice
-Sample of the BSoDs I'm getting:
Any ideas? If this doesn't work I'm getting a damn netbook.
Cheers
-No thermal issues
Code:
On Tue 15/03/2011 19:33:49 GMT your computer crashed
crash dump file: C:\Windows\memory.dmp
This was probably caused by the following module: ntkrnlmp.exe (nt!FsRtlInitializeBaseMcbEx+0x4345)
Bugcheck code: 0x1E (0xFFFFFFFFC0000005, 0xFFFFF80002EAB9BF, 0x0, 0x107)
Error: KMODE_EXCEPTION_NOT_HANDLED
Bug check description: This indicates that a kernel-mode program generated an exception which the error handler did not catch.
This appears to be a typical software driver bug and is not likely to be caused by a hardware problem.
The crash took place in the Windows kernel. Possibly this problem is caused by another driver which cannot be identified at this time.
On Sun 13/03/2011 02:23:40 GMT your computer crashed
crash dump file: C:\Windows\Minidump\031311-18174-01.dmp
This was probably caused by the following module: hal.dll (hal+0x12903)
Bugcheck code: 0x124 (0x0, 0xFFFFFA800544C028, 0xB669C000, 0x175)
Error: WHEA_UNCORRECTABLE_ERROR
file path: C:\Windows\system32\hal.dll
product: Microsoft® Windows® Operating System
company: Microsoft Corporation
description: Hardware Abstraction Layer DLL
Bug check description: This bug check indicates that a fatal hardware error has occurred. This bug check uses the error data that is provided by the Windows Hardware Error Architecture (WHEA).
This is likely to be caused by a hardware problem problem. This problem might be caused by a thermal issue.
The crash took place in a standard Microsoft module. Your system configuration may be incorrect. Possibly this problem is caused by another driver on your system which cannot be identified at this time.
Cheers
fingers crossed it stays this way
Got a MEMORY_MANAGEMENT BSoD this morning (SP1 wouldn't install, and eventually it gave out) and 4 hard locks. Problem is it always hard locks while writing minidumps too so no clue on it.
