Recently picked up an E6600 and I must say its rather toasty...
Currently running at 3.2Ghz 400Mhzx8 on 1.375V and its sat at 62C load...
Thats on a Scythe Ninja B using AS5, the cooler is fitted fine, i've even removed it and reseated it with exactly the same results.
The Scythe is also lapped.
As far as I can tell the E6600 isn't concave and when I remove the Scythe the AS is spread evenly over the entire CPU.
It's all housed in an Akasa Eclipse case with good airflow.
Anyone got any ideas as to why its running so hot? would lapping the CPU help even though the IHS appears to be flat?
EDIT - Ooops can someone move to Cooling, cheers!
