Hi there.
Have just put together a new rig for the server at my new job, using the above cpu and an Arctic Cooling Freezer 7 Pro. Idle temps with the processor at stock using the compound provided (believe it to be MX1) it is idling at abou 45-48 degrees in the BIOS.
Also, the NB temp is sitting at around 75-78 degrees, this is on an Intel DP35DP motherboard.
Are these normal temps or is something going amiss?
Thanks very much for looking, any help appreciated.
