VESA Desk Mount Recommendations
TNA
TNA
Caporegime
13 Mar 2008
London
Just the DGM 27" LED IPS 2560x1440 monitor. I have not even turned it on yet. I noticed the stand is competently inefficient for the size. It wobbles like mad. lol. Worried that one day I will bump into my desk by mistake and it will come crashing on to me. This means a new desk mount will be in order.
Can you guys recommend good VESA monitor mount that is under £50? Don't really fancy spending more than that. £20-50 should get something decent I think. Want something sturdy to attach to my desk and be able to move it in most if not all directions ideally.
Cheers :)
I would like to know this answer as well. I currently have a few earmarked on Ebay for £29.99 but not bought one yet.
Just noticed, one guy has one in the DGM monitors thread. He said he got it from ebay. Hopefully he replies with more information.
"MDM04 Single LED/LCD Monitor Stand w/ Swivel Arm & Desk Clamp"
Technical Details
Mount one LCD monitor to desktop, Fits all LED/LCD TVs & Monitors with VESA 50 75 or 100 mounting holes but not heavier than 6Kgs each (13.2lbs each) in weight
Tilt up/down, pull out / fold in, swivel left/right
Heavy duty metal, support LED/LCD monitors up to 6Kgs (13.2lbs) in weight
130° rotation, 30° tilt up and down, adjustable height
Package includes desk clamp, easily clamp the monitors & arm bracket to the desk
Bought one of these from the rainforest and couldnt be happier with it.
sturdy, strong, well made.
I think the dgm is about 10kg , i posted a pic of my mount in the dgm thread, its ok as long as you dont have it fully extended.
Thanks for the reply man. I think the 10kg weight is it including box and stand etc. The net weight is just under 8kg after you remove the stand I believe.
I ordered the same as your one, as I was not convinced by the rest. May have gone for the one sold at ocuk which was just under £50, but the lack of info such as how much weight it can take put me off. Did not fancy paying £20 extra for something that did not look much better.
Ergotron MX are quite well regarded around here. Bit steep at ~£100 though. I think I remember someone talking about a gas operated one being released soon but can't remember who where when.
