Vesa mountable cases?
My work uses these tiny HP systems with a 1000mhz via eden processor and they screw onto the back of the monitor. They do a modern version too which is ok for H.264 and media purposes.
Scythe Kozuti seems to be the cooler most use, I think you have 53mm clearance, but you could always cut the mesh panel and put in a bigger cooler or even attach a water cooler
