VESA screws?
26 Jan 2005
Cheltenham, UK
Hi Guys,
First off I'll say I hope this doesn't conflict with OcUK. If it does please alert me.
I need to buy 4 VESA screws for a DGM L-2231WD. Anyone got any ideas what size I need and where I can buy them from?
Cheers jmhduck
VESA should be a standard, but I guess it might vary by screen.
I can't help, but will jump in to ask if anyone knows what the screws are in terms of pitch and nominal diameter I'd like to know
From Wiki posted above:
MIS-D75 & MIS-D100
M4 x (10mm + thickness of steel for the mount)
This will be standard and M4x0.75
Looks like
MIS-F has either M6 or M8 which is M6x1.0 or M8x1.25 (End number is the pitch and a standard thread).
I could but M4 screws in whatever length I like from the local engineering shop. Can probably get them in any DIY store, but they'll be about 6 pence each from engineers
