Vesa Wall Mounting Brackets
27 Apr 2007
Hi All
I want to wall mount a new 27" Monitor but I can't find a suitable bracket.
Does anyone know of a supplier in the UK please?
Thanks
Alan
Thanks I already found that.
I want a Tilt and Swivel mount to go on the wall in front of my desk,I even tried ebay but no luck there.
Alan
On an arm I think
I have been to IIyama's website and they do some Tilt and Swivel for their monitors.
I also found a company called BracketsRus that do a good range.
Alan
Indeed, those sorts of sites are ideal, but don't forget eBay and other marketplace sites as some sites are a total rip off.
You can pretty much ignore the size and weight requirements as they are mostly for Tv. Monitors are generally much lighter and even the most basic of steel brackets will support the largest of monitors. Just make sure it supports the VESA standard your monitor uses, usually 75 or 100mm spacing between the holes.
