Vetroo v5 cpu cooler
30 Oct 2015
Good morning my vetroo v5 120mm rgb fan is faulty and would like just to replace the fan with same or similar 120mm argb fan .Any reconmedations as few i have seen only have max 1100PRM and the one that came with vetroov5 had max 1700rpm. would like something similar
You need a high static pressure fan which usually runs faster the 1100rpm is probably a case fan.
This is a good fan for the money but is does run faster at full speed 2200 rpm but you should be able to set max speed in the bios to your liking.
