- 24 Apr 2012
Hi all,
I got my new monitor today upgrading from a 23" syncmaster, after tweaking with the colours i'm happy but when attempting to set up the 3D i only get an "out of Range" message.
The only possible solution i found online was to reduce the resolution to 1280x1024 at 60Hz, i did this through the control panel with no success.
Has anyone else had this problem or know of a solution?
My GPU is a GTX670 in case this is a factor
I read that you need to use the DVI cable to use 3D, i have been using my HDMI,this is because on the dvi setting i have my wallpaper but no windows bar or mouse, its just a picture.
