VGA block help - 780ti.
27 Feb 2012
Had a little idea in one of my many brain cells.
I only use 1 card for gaming, even if i had multiple in my machine. Normally CF/SLI is disable and the second card is for looks.
My brain told me to have both a 780ti and a 290x in the machine at once so i can bench wither either or. What i need to know the distance from the PCI brackets and the FC block terminal. If they match the 290 block i can connect them without any fuss, if not...:(
Already have a 290 block, so needing 780ti with EK FC blocks to measure if that's alright.
I'd have thought switching cards would involve a cable swap and a reboot even if you do have both installed at the same time.
