Vga Box for AG Neovo F419. Any suggestions?
13 Feb 2006
Long time watcher, first time poster.
I have just got a AG Neovo F419, as my first tft i'm very pleased with my purchase. My pc is hooked up through the dvi and i want to hook up my many consoles to the vga cable.
I bought the Logic 3 VGA+ at the weekend and it is rubbish. Metroid prime on the cube will only display in B&W in 60hz mode and in 50hz at all the resolutions it is worse than any tv. Didn't bother moving the xbox after that. Will be going back today.
I'm looking for a good vga box that will handle Psone, n64, snes, cube and xbox as my wife is feed up with me hogging the tv! I do have a vga box for my dreamcast but one unit for all is the ideal.
Any suggestions/advice greatfully recieved. There are so many out there and so little info on the net. Looking for the best picture possible.
Cheers.
I think it is a really great monitor for the money. Upgraded from a 15"crt so it is Huge! Comparable to the 21" crt i have at work. I use Autocad a lot at work and home and it is great for splitting drawings horizontally so you can see the other for reference.
Have only played GTR racing on it so far and that performed really well, no obvious ghosting, i just need to learn how to keep it on the road! It has been great with two inputs on it as my new pc has dvi and i can plug my old one in at the same time and switch between them via the monitor buttons.
No dead pixels either so all round very pleased.
Now just to find that vga box.
