VGA Cable with the DVI adaptor
12 Aug 2008
Very simple question. I was wondering since I'm going to be connecting my build via VGA cable, does using one of those VGA>DVI adaptors make any difference? or does getting a brand new DVI>DVI cable all together make a difference?
Thanks
Hey,
Would something cheap like this be fine?
Going to be running at 1920 x 1080 resolution.
Does cheap vs more expensive cables matter in DVI? or is it like HDMI where it doesn't really make a difference?
Thank you
