VGA Cable
Just to link my PC to my TV screen. I've tried it and it works fine but the cable is too short and I had to move my computer right out the way. Just need a longer one.
You'd be better using a DVI-HDMI converter, then buying a 5M HDMI cable. Will be a lot cheaper and you'll be able to use it in the future as VGA is on the way out really...
