So I got a Xenta VGA cable and I hook it up to my TV and try and set the resolution at 1920x1080 and all I get is a black screen and the TV saying check signal cable. I can only get resolution like 1600x1200 working and even then only with ghosting all over the screen. So I get a replacement shipped out to me and it has exactly the same problem!
Now I know its not the computer or the TV because I have an old VGA cable that works just fine.
In fact this is the exact cable I ordered but I got it from another site.
http://www.overclockers.co.uk/showproduct.php?prodid=CB-014-OK
Does anyone know of a good VGA cable that can actually display Full HD resolutions and not be affected by ghosting?
they do a wide range of vga cables good quality too
