Raikiri said:
Slime said:Nice idea, i may even run it fanless! Cheers mate![]()
Accelero X2 is good too if you just want quiet operation on a budget.Slime said:In which case i may opt for the cheaper Accelero as I need to make it fairly cheap. Will it still keep it quiet?
Think the Accelero is your best bet then, supposed to be as quiet as (if not quieter than) the VF900 and it's cheaper.Slime said:I'm not too bothered if the temps stay the same as i've not overclocked it or anything. Getting it as silent as possible is my main priority.
