VGA Coolers
26 Aug 2006
i have a Leadtek A7600 GT AGP its a month old clocked to 590/775 temps ar 45c idle and about 68c full load i have been running artifacts scaning tool from ati no artifacts i just got a zalman vf900-cu led from overclockers today and the dam thing wont fit :mad: can anyone recommend a good cooler for the card or just leave it with the standerd cooler on it :D
i bet its your bridge chip which is getting in the way. best to stick to the stock cooler since 68c is perfectly fine if thats the load temp generated by ati tool
in gaming you will notice that your card will never get as hot as what ati tool can get it to.
