VGA light randomly ( randomly hangs on POST )
17 Feb 2024
BRAZIL
Hello
I´ve been having a persistent issue across 3 pc builds
it started on the first one : msi mpg b550m , xpg pylon 650w , 5700x3d , 32gb ram ddr4 4 sticks , rtx 4070 eagle
my pc would randomly hang on the vga light boot process , the light wouldn´t just lit but the pc will stay there crashed at the vga light
so i went there and swapped gpu for a 4070 super , problem persisted
got a new mobo ( tuf b550m) problem persisted
got a new psu ( core reactor 650w ) problem persisted
swapped the kit with my brother ( he has a tuf b650m-e wifi , 32gb dual kit 6000mhz ddr5 and a ryzen 5 7600 ) and the problem persisted
even swapped ssds to test and still there
so , swapped the whole pc and still happens
even got new hdmi and dp cables to test and still happens
swapped my case as well
can my monitor or tv cause the pc to crash ? (both monitor and tv works )
what is being used between builds : one line filter for tv , one line filter for monitor and pc , logitech mouse g305 , redragon keyboard dragonborn brown , hs65 surround corsair
my peripherals are all usb ( 3 usb devices in total )
i´m wondering , is there something wrong that is causing it ? can my line filter crash the vga light ? or maybe the usb devices are causing it ?
is there something else that i should look for ?
thanks
A poor quality surge protector or multi-block can cause odd behaviour. Have you carried over any fan or led hubs?
no , just use 3 case fans without splitters and use the ag620 cooler with the rgb in each fan on one slot in the mobo for each
this line filter is the best here in brazil , i don´t have any instability once the pc boots but do you think it could still be the culprit ?
Possibly - I can't see how it could be your monitor, keyboard or mouse. Is there anything in event viewer around the time of the issues?
You might want to look into a UPS.
i have to say i´m using a hs65 surround corsair (usb as well )
i just can´t understand why it wouldn´t shutdown the pc etc... if the filter was the problem
can we take out case fans or rgb things being the problem ? i guess this is the cpu light process , to detect a working cpu cooler
i´m running a time without the headset , is it possible for it to crash 3 mobos ? i always used the leyboard , mouse , headset and line filter in the 3 mobos tested
When you swapped the PCs did you try yours at your brothers? did he have the same issue?
Have you tried another line filter or without it?
When did the issue start? was anything changed around the time the problems started?
Can you clarify, do you mean when you press the power button the fans spin up but the screen stays blank and keyboard leds don't come on?
Are you using the USB headset adapter?
I've seen a damaged USB port on a desktop PC stop the PC powering on so yes if theres a short the PSU protection could be kicking in.
I've also seen PC's hang when detecting USB devices, you could try disabling USB boot first but you might need a new headset.
i´m running without the usb headset to see if it crashes by now
i remember changing mobo , case and the headset when this happened , since i believe it could be the headset
yes , this is exactly what happens ( happened on 3 motherboards , even on a am5 one )
this corsair headset is p3 but with the usb dac included , always used it with the usb dac
i don´t know if i´ve been unlucky enough to have 3 damaged usb ports on 3 mobos
how can i disable this usb boot first ?
did i damage , run any risk of damage during this time , when it crashed on vga ?
what i just can´t get over it , if there is a short , wouldn´t the pc shutdown during use or something like it ? it never happens this during normal use
also why it boots fine and sometimes it hangs ?
thanks
You've been trying it without the USB headset, is it still booting ok without that connected?
Was the headset DAC connected to the rear MB ports? What happens if its connected to one at the front?
In the bios options disable boot from external device / set it to only boot from your SSD.
If it works ok once it boots then it sounds more like its waiting for something / training the ram. If there's a fast boot option in the bios maybe try turning it off so you can see what its doing.
If its working without the USB DAC then you probably need to replace it otherwise Id ask someone if they have got a keyboard / mouse you can borrow for a bit because you have replaced everything else.
Intermittent faults are difficult to fault find, a bad cable, the case pushed too far back knocking the USB DAC etc, even starting a PC when its cold or damp can cause issues.
1 : so far so good but too early to just assume it is 100%
2 : always tried at the hear , is the usb hub from the case any different from the ones in the mobo ? i also think it could not be the headset in particular but maybe a third usb device that gets too "much" with the mouse and keyboard ? are 3 usb devices too much for it to handle ? it is weird that this behavior reproduced itself in 3 mobos but who knows
3 : ah i see , mine doesn´t have this option , nor it was present in any motherboard i´ve tested i think
4: sorry , bit newbie question but what does this fast boot do ?
5 : i know the kb and mouse can age as well but i´ve been using them a long time and between builds and they always work , the headset is the new stuff , since i´m suspecting it
6 : i´ve double checked 3 builds , mobo standoffs etc , they all are fine ( back panel etc ), cables swapped as well
but what do you mean by starting the pc cold or damp ?
thanks
i also have the habit to turn on pc first then during the post i turn on the monitor/tv or vice versa
sometimes monitor/tv first then the pc
Then I would leave it disconnected for a bit and not change anything else yet, then update the thread in say a week unless it happens again sooner.
Its common to have different USB controllers, e.g. the rear might be USB 3.x, but some of the headers for the case might be USB 2.
No the number of devices doesn't matter a kybd, mouse and DAC shouldn't draw much current so unless one is faulty and it can't identify it or it trips the PSU safety circuit because theres a short.
I don't know what BIOS options you have its probably just called something else, boot sequence etc but somewhere there should be an option to disable USB boot maybe under security options or something it just stops the PC looking for a different boot device.
Again I dont know your mobo so it might be called something else but theres usually an option that can change how long the BIOS spends running checks during POST. So if fast boot was switched off the tests would take longer but would be more thorough.
On old motherboards there used to be a BIOS option to ignore POST errors and continue booting, there was a specific setting to continue booting if there was a keyboard error e.g. a headless server would still complete the boot process if the keyboard wasn't plugged in.
So a keyboard fault can potentially cause boot process to fail but I would expect an error message on the display not a blank screen.
At the moment it looks like an issue with the USB DAC.
Yes but you still have a fault, its looking like it might be an issue with the USB DAC.
You say Monitor / TV so you have them both connected to the PC at the same time?
You have changed the mobo and PSU so this isn't your issue but I've known of PC's that have had a PSU / Mother board that is starting to fail work fine except when they are switched on in the morning when the room temperature is lower.
hmm i see , it makes sense
i´m using the headset throught the p3 mode , ignoring the dac at all to see but i´ve extensively tested already ( 4 days ) turning the pc on/off and it hasn´t appeared with the dac being removed from the pc
just started using the p3 on the pc today , i doubt a p3 device can crash ( because it is bad to use without sound )
is it ok going to p3 or should i remove it completely in the mean time ?
i always had a tv and monitor connected through my gpus over time (1060 , 3060 , 4070 now )
even used worse cables as well and never ever faced the vga light
but i know something was wrong since i´ve swapped the gpu , mobo , psu , drive etc and it still pointed the vga light which clearly is not
this current mobo is a tuf b650m-e wifi ( also not using the wifi/bluetooth antenna for the sake of it)
i´ve typed usb to search in the advanced mode and could not find any boot from usb device or anything like it
note that all mobos tested it was mostly with default settings , i´ve never changed some specific setting in any mobo/bios
let´s see , the next step could be the line filter i guess
is this damaging the pc or is it ok if i ever face this vga light again ? or this is just the protection kicking in maybe ?
but yes , considering it could be the dac crashing it but i´m afraid it may point to something else like filter being bad , possibly damaging something
the psu is a core reactor 650w
thanks
i also wanted to know , if it gets stuck in the vga light , should i wait some more time maybe ( to see if it actually posts ) or let´s say , if i remove the problematic device , would the post continue to occur ?
If its still working without the USB DAC then I think you have already found the fault either the DAC is bad or causing some sort of conflict and I would probably just ditch the DAC.
If you disable onboard audio in the BIOS does it still hang when you boot with the DAC plugged in?
Are their any firmware updates available for your motherboard?
Are their any firmware updates available for the DAC?
Have you tried with just the monitor connected?
Have you tried with just the TV connected?
If you want to rule out the line filters then just disconnect them for a bit and reconnect the DAC but I can't see why it would start working without the DAC if the line filters are faulty.
Another thing to try is booting the PC without the DAC plugged in then plugging it in after you have logged into windows.
You should have audio over hdmi to your TV and possibly your monitor as other short term options to using the DAC.
If its a conflict or the bios cant detect the DAC correctly for some reason then no it shouldnt damage anything; if the DAC / USB cable was shorting the USB port that might not do it any good but you have said it works once you get into Windows...
yeah , it 100% works once the OS loads
all peripherals work 100% ( the whole pc works tbh )
but it is annoying sometimes , it crashes the bios ( i don´t have to reset cmos ) and i have to reapply ram oc etc
i´m using oced ram but it doesn´t matter as it still within spec and used ddr4 ram as well , it still showed the vga light
so far so good , will keep posted if happens again
i´m using the headset throught the p3 port in the front hub of the case
i have another question as well , does the p3 hub from the case consider the motherboard audio or it has it´s own audio chip ?
it is bad since the dac has some slightly better quality than direct p3 but it is usable overall ( better than spend again lol )
removed the hub so far , no other changes during this mean time
Yes the 3.5mm headphone socket on the front uses the motherboard audio so the socket wont work if you disable onboard audio in the BIOS. I just wondered if the DAC would still cause the PC to hang at boot if the onboard audio was disabled.
Heres one of the threads I stumbled upon basically saying Corsair / ICue = bad
hmm i see
worth to try disabling the onboard audio since it is not being used anyway with the dac
i´ve searched and seen reports of corsair keyboards hanging boots as well
too bad this headset is pretty good and unfortunately the p3 has slighty lower quality overall
i´m wondering if it is worth to disable hardware checks when i turn on the pc ?
thanks
