VGA monitor problem
20 Jul 2007
Preston
Im running a eyefinity setup with 3 dell 24inch st2410's. 2 are running dvi cables and im running a display port to vga adapter.
My problem is that the monitor using the vga is refusing to go into the correct res, its running 1600/1200 instead of 1920/1020.
I know I could get a display port to dvi adapter but I would rather not spend 80 quid on it.
Thanks.
Just some cheap one, it has been to its native res of 1920/1020 before but its refusing to go into it now.
Edit, its just gone into its native res but when I change to eyefinity it breaks :( lamee
Try switch the monitors around. If the problem still occurs with the DP port, maybe a different DP -> VGA adapter might work?
I switched them around and the vga monitor started working for while using all 3 screens but when I grouped them for eyefinity it forced all 3 to be on the a 800/600 screen because the vga screen doesn't like it.
