VGA monitor with GTX 960
13 Nov 2013
A mate has a VGA monitor he wants to use with a 960 (windforce). Would a simple DVI adapter be enough to use it? Will there be performance hits?
VGA is still on most cheap 1080p monitors and works without issue as VGA is more than capable of carrying 1920*1080 60hz signals.
A DVI to VGA adapter will work fine and wont have any negative impact other than perhaps a very minor reduction in the overall image quality.
I don't know what monitor it is but its fullhd, bought last year so no tube etc.
I'll suggest using the adapter, thanks.
