Vga out
7 Jan 2003
Leicester
Which agp cards have vga out as i want to connect to my lcd tv input .also does taking a out from dvi but using a dvi to agp connector into vga input work I tried it with the 6800 ultra but no picture?
I want the fastest agp card that has vga out please
thanks
thanks
Err.. slightly confusing post.
Most if not all AGP cards output SVGA signals over either a 15-pin d-sub or DVI connection.
What's a DVI to AGP connector, do you mean DVI to SVGA dongle?
If you connect (assuming the LCD is a d-sub connection)using the DVI to the LCD via the dongle it should work. If the LCD is a TV not a monitor, they can be fussy and may need you to set the right frequency and resolution or you may only get a blank screen.
