Hey guys,
So herein continues the ongoing saga of my pc...
Spec is: 3000+, DFI Lanparty, 2*512 2700, 6800, sata hdd, Tagan 480W.
This all worked fine, all be it with a 9800, in my old case. When I changed to my V600, I had problems getting it to work. Tested as much as I can, but I can't narrow it down to one component.
Current position is: PC is build on my desk (not in case). Yesterday, PC would come on for 2 secs, then go off. Reseated everything. PC now comes on, stays on, but there is no output on the VGA. Ive tried different CPU coolers (for contact), two gfx cards, and shifting the RAM around.
Aside that, i'm stumped
I know the spec is a bit dated, but I'd like to try and get it working before I look at replacing parts.
Cheers, James
Cheers, James
