Hi people,
Quick question for you experts out there please!
I have 99.9% finished putting my gaming rig together.
The problem I have is confusion caused by 1 power supply and two graphic cards.
1x Thermal take 1200w Modular (plug in cables).
2x ATI 3870x2
Each Graphic card has two power connections. One is 6 pin and the other, 8 pin.
In the power supply manual it states the following:
"Please be noticed that when trying to connect more then one connector to a graphic card, it is strongly recommended to choose the connectors from exactly the same +12v rail."
-----6 pin 6pin 6 pin 8 pin 8 pin 8 pin
12v3 --x---x -------- x-------------
12v4 ------------x---------x----x---
Can you see why I am confused? Can I not just plug the buggers in?
Thanks,
Chris.
2x ATI 3870x2
Thanks,
Chris.
