VGA screen ---> HD PC - Help?
So the screen has VGA only? What does the PC have?
If the PC has DVI-I (note the four little connectors near the flat "blade" on the wikipedia pictures) then you can get a passive DVI to VGA cable which will work fine.
Anything else is probably a no go without an expensive active adaptor.
Aspire XC 704 is the PC which supports HDMI
VGA is the screens output
