VGA switch box
18 Oct 2002
I have a plasma TV with a VGA input that I use for my HTPC.
I sometimes plug my laptop into the TV which involves swapping the VGA cable over.
Is there a box that allows me to connect 2 (or even 3) VGA cables and then switch between them as required?
A quick Google has thrown up nothing obvious...
Thanks.
I'd go for a VGA switch unless you research which KVMs will work without complication...the added function of a KVM over a simple switch sounds like it'd be of no use to you.
You may lose a little picture quality, especially at high resolutions. Can you plug the HTPC into a digital connection (HDMI/DVI)?
No, unfortunately it's VGA only unless I spend £100 on a new terminal board for the telly.
As you point out, a KVM switch is possibly overkill - I'll only be using the VGA portion of it.
The search continues...
