I purchased a 22" V7 monitor from OC several weeks ago, with the intention of running my PC via the VGA & my 360 through the DVi with the use of an converter.
I have both component & VGA leads for my 360 so I decided to get a DVI-M TO VGA-F converter which I ordered via the bay see link
http://cgi.ebay.co.uk/ws/eBayISAPI....from=R8&satitle=270115931022&category0=&fvi=1
Now the problem I'm having is that this converter has 4 pins around the flat blade on the DVi side (see ebay pic), my monitor however does have these 4 holes for these to go into
so I've been unable to use it
Just wondering if those 4 pins on the converter are standard to DVi or not and if they are why does my monitor not have the correct input?
