vga to rca
What are you needing them for exactly? There may be a better solution. If its even possible to make a cable like this, composite (rca) looks awfull compared to vga.
I assume its so you can connect your computer to your tv? If so i have seen a fev vga to s-video converters around, although i havent found anywhere that sells them. Im also interested in this too.
im wanting to rig 2 displays up to my htpc one psone lcd modded in the fornt just for looks and my telly only problem is i dont whant to pull apart and mod the screen to fit the vga port so its gonna have to go to the s video on the grfx card so this means my tv will have to go to the vga port
A few different connections use rca connectors on their leads, are you talking about a component connection or a composite one?
I can find vga to component leads but not composite ones.
The only other thing I found was these boxes http://store.grandtec.com/pctotvcon.html no idea if they are avalible in the uk though.
