VGA vs Scart - much difference?
20 Mar 2003
On the stool at the end of the bar
Currently contemplating buying a VGA cable for the 360 but is there really that much difference between VGA and scart?
Thanks!
Erm yeah a massive difference, a lot better resolutions with vga, as in hd quality. Vga is supposedly even better than component, expect its meant to wash the colours out a bit. Use vga, you won't regret it, or even component.
You using a hdtv? Guessing you are tho :rolleyes:
this will be displayed on a 32" Toshiba HDTV. Not sure what model though. Sounds like i shall be picking one up on the way home!
Cheers!!
Remember to select one of the higher resolutions when you start using the VGA. No point in using it at 640 x 480.
