I'm going to water cool my Asus 2gb 770, I've used the EK configurator to find a suitable block for it not sure if I can link to it or not. The picture shows the main plate with 2 holes in it for the water input and output like in the example one below. Can I run connections directly off these ports or do I have to use the extra block which extends them out?
The reason for asking is that it will hopefully be going into an In Win 901, the heat pipes on the stock cooler are already nearly touching the glass side panel so there isn't the room for the extension piece for the water block
Example water block with ports on the main block:
http://www.overclockers.co.uk/showproduct.php?prodid=WC-226-EK&groupid=962&catid=1520
Gpu:
http://www.overclockers.co.uk/showproduct.php?prodid=GX-307-AS
I hope this makes sense
Gpu:
