Vibrating tower walls
5 Dec 2006
Wasn't sure if this was a "case" question or something more to do with "noise" so I put it in here...
..just wondered what the best solution was for a little noise coming from the sides of the LianLiV2000 i have. It's watercooled and the low vibrations are either coming from the pump, fans or both.
It doesn't happens all the time, and if I place my hand on the side of the case it stops.
However if it is in the mood to be "doing it" it starts again when you take your hand away.
The sliding walls are screwed in tightly at the back.
I don't have that problem myself, but an easy solution I've seen suggested in here is to put some blue-tack along the edges where the panel meets the case.
PK!
