- 30 Dec 2003
- Bigger box!
Spent bloody ages googling solutions and I'm not really getting anywhere
I have two pretty significant problems which are really ruining my chance to replay this great game!!
I can't get the resolution above 680 x 400. In the menu all I can change is the colours between 16 and 32 bit?!?!
All my googling tells me is that you have to change resolutions before playing the game but that's not the issue!!! Grrrrr
I also have the PS2 to USB adapter from that Jersey company which works a treat apart from the right analouge stick.
On the right stick or Z axis and rotation up is left, right is up, down is right and left is down.. Basically it's as if its beet turned 90 degrees to the right.
If you can help I'll hug you and stuff
