Vid Pid??
21 Feb 2006
Southampton, UK
Hi guys, just got vista ultimate and still in the basic setting up stages, however i am having trouble getting my USB wireless adapter working.
It's a BT voyager 1055 adapter, and won't install using the disc, as setup fails as soon as it starts. So i downloaded the drivers which were said to work with vista, however during the install i have a prompt come up saying:
"Add VID/PID"
Any ideas what this is, or how to get round it??
Thanks.
Start > Run > MSINFO32
Components > USB > Look for your device in the list (should say USB\VID_XXXX&PID_XXXX)
Thats the info you are looking for. Dunno if the above is available in Vista or for hardware that isnt fully installed. If you have a machine with Windows XP on it which works then it might be worth grabbing them from there
Quick Google shows the following thread too - http://www.winvistabeta.com/groups/1332320/wireless/message.aspx
