VID & Power fluctuation
13 May 2011
Hello, Ive got some basic enough knowledge when it comes down to overclocking ect but I've got a few questions. Here are the specs and settings first though :
i2500 @ 4.5ghz
Asus P8P67 Intel P67 Pro
Rest of the rig is in the sig
Manually set in bios :
1.3V - CPU voltage
Phase Control - Extreme
PPL - 1.81250
Basically when idling core temp shows the VID @ 1.2310 > 1.3010 > 1.26610 and alternatives between them similarly with the power going in ranges from 7-10w while the cores are all under 6-8% load.
Basically.. is this normal or do i have a problem?!
Just ignore it, the VID is something physically programmed into the processor it's probably just a glitch with coretemp, I think my 3930K changes under coretemp as well I just ignore it.
The power will fluctuate depending on how much load is on the processor.
