Vidahost and running php from within .htm files
1 Jun 2007
Anyone on Vidahost got php running from inside .htm files ?
I added:
AddType application/x-httpd-php .htm
AddType application/x-httpd-php .html
to .htaccess but it seems it doesnt work Vidahost has some custom stuff going on.
Got it working with this:
AddType application/x-httpd-php5 .htm .html
Although SSI includes eg, #include virtual= dont work anymore.
EDIT: nvm got it working using:
AddOutputFilter INCLUDES .htm .php
You can specify the rewrite rules in .htaccess, was the point I was making.
Sure but:
"Doing it in .htaccess uses mod_rewrite, if you are rewriting."
Implies that it automatically uses mod_rewrite. Its separate from the .htaccess file and needs to be enabled by the webserver.
It's trivial to enable it. It's even enabled on a default installation. 99.99999999% of webhosts have it enabled already.
