I've just set up an spf with my provider to stop some spam problems, but it it hasn't had any effect after 36hrs.  Vidahost said dns/spf update should take 24hrs.
my record looks like this:
Which is what I made out from this http://support.google.com/a/bin/answer.py?hl=en&answer=178723.
I'm not sure if vidahost will be of much help in verifying this since they suggested using this microsoft tool http://www.microsoft.com/mscorp/safety/content/technologies/senderid/wizard/ which gives a very different record.
It would be great if someone could confirm if what I have is correct, or otherwise fix it
Thanks
ps, thread could probably go elsewhere but I'd appreciate the visibility of GD, at least for a bit.
		Code:
	Name                 TTL      Class      Type      Record
mydomain.co.uk       14400     IN         TXT       "v=spf1 include:_spf.google.com ~all"Which is what I made out from this http://support.google.com/a/bin/answer.py?hl=en&answer=178723.
Thanks
