Video Being Zoomed In On Premiere Pro Timeline
23 Sep 2007
Essex
Not sure if this is the right section, so please move it if its wrong.
I'm trying to make a video with Premiere Pro, and as you can see from the image, the output is being 'zoomed in' on the timeline and the resulting rendered video. I've checked the settings and my Googling skills are letting me down :(
Is there any video experts here that can help me get the video so it matches what was recorded??
Thanks in advance!
*edit* can someone delete this, I think I figured it out. Thanks :)
The transform setting is what you use to adjust the size of the video clip as it's ilaced on the timeline.
The output monitor box also has a zoom level for what it displays. Unless you need something else, I usually have it set to fit so it scales to the space.
I figured it out in the end. Im new to editing, and the first thing I imported was a picture and the timeline was set accordingly. So when I added 4k video it was adjusted to the picture.
I redid it adding the video first and the picture towards the end.
Im still learning but I was happy in the end :)
