Hi,
I'd like some advice on the best upgrade path available to me.
Firstly here's my current system-
Asus P4C800
Intel P4 3.2 HT Prescott (freezer 4 cooler)
Powercolour X800 Pro 256 Mb (softmodded to XT, running at 500/500) AGP (/w VGA Silencer)
Twinmos DDR400 1.5 GB (dual channel, 2 * 256, 2 * 512)
Maxtor SATA 150 HDD 120 GB
SB Audigy 2 ZS
Thermaltake Tsunami case
Dual 12 cm LED fans / Nexus fan controller
LG DVD writer
Enemax Noisetaker 475W dual rail PSU
Some good stuff there (apart from the rattley TT case
), or at least it was good when I bought it all. Runs nice and quiet too.
The first obvious things is - clearly most of the current system has to go. The video card is AGP, so is the motherboard, so any worthwhile upgrade (IMO) means a switch to PCI-Express, so that means at least a new motherboard, new CPU and new video card.
From a price point of view I'm looking at A64s, Socket 939. A64 4000+ at £117 looks about right. Possibly I'll get the OEM version @£105 and an AC Freezer 64 since I've owned a few AC coolers (see above) and been impressed by them. For the video card there's the Connect3D X1800 XT 256 mb at £170 or a HIS 512mb version at £205. My current card is 500/1000 with 16 pipes (ps2.0), so I'm only going to consider something significantly better. 625/1500 with 16 pipes and ps3.0 would be enough to be worth it IMO. I suppose 7900 GTs are another option - there's the BFG version which is 475/1360 with 24 pipes and ps3.0 at £192. I will of course be checking out benchmarks before deciding on a video card.
Motherboard wise I'd like to stick with Asus, but I'm not too fussy here. Asus A8N-VM CSM Micro ATX PCI Express Motherboard at £55 seems to do everything I need since I'm not bothered about crossfire/SLI. I won't be using the onboard video/audio btw. Memory - I'm not budgeting for this at the moment since I want to see if my current ram works with the new motherboard first.
I'm looking to spend about £400.
So, questions-
-is it wise to go Socket939 still? Is it in danger of becoming a dead-end any time soon ?
-does this look like a good value for money upgrade ?
-are these good choices ?
-anything wrong with that relatively cheap motherboard, remembering that I'm not interested in crossfire/SLI ?
-any reason why I shouldn't get a motherboard with onboard video, given that I'm not going to use the onboard video ?
-am i missing anything obvious here ?
Thanks a million,
Simon.
Asus P4C800
SB Audigy 2 ZS
LG DVD writer
So, questions-
Thanks a million,
Simon.
