- 1 Sep 2016
Hello,
One week ago I build my first ever computer, it took me 14 hours to do that but I am very pleased with the result (it took me 6 hours to build pc and another 8 hours to install windows {for some reason skylake does not like windows 7 to be installed from usb and it took me long, long time to understand that}), anyway I have a question about what monitor and video card should I get next, thanks.
Currently I have 1080p monitor @ 60 Hz and it's running very good but i got this monitor for 50£ and for a computer what I have now, I need a better monitor.
I was looking at 2560x1440 @ 144 hz - that would be great upgrade for me (before that I had laptop for past 6 years witch was running League of Legends at 30-40fps on a very low resolution), is there any video card witch can run 144+ fps on maximum settings at 1440p ? Otherwise what is the point buying 2k monitor if you can't max out everything and "flying" around 60 fps ?
I saw some benchmarks for GTX 1080 and even this video card can't get 144 fps at 1440p but it's recommended video card if you like 1440p gaming.
Should I stay than on 1080p, upgrade my video card to 980TI and buy a 144 Hz monitor ?
I can save money and indeed I am not in rush, just going for a goal. I can buy two GTX 1080 if they are going to give me that performance what I am looking but I don't see point buying 2k monitor with 144 Hz if you can't get that fps with your video card.
Please give me as much information you can. I have to say that I have done my own research but nothing gives me a clear answer and I would like to hear what you guys have to say as you have lots of experience and you can answer on my direct question.
Kind Regards
Intel Core i5-6600K 3.9GHz (Skylake) Socket LGA1151 Processor - Retail
Asus Z170-K Intel Z170 (Socket 1151) DDR4 ATX Motherboard
Corsair Hydro Series H100i v2 Extreme Performance Liquid CPU Cooler (CW-9060025-WW)
Corsair Vengeance LPX 8GB (2x4GB) DDR4 PC4-24000C15 3000MHz Dual Channel Kit - Red (CMK8GX4M2B3000C1
Kingston HyperX Savage 240GB SSD 2.5" SATA 6Gbps Solid State Drive (SHSS37A/240GB)
Super Flower Leadex GOLD 850W Fully Modular "80 Plus Gold" Power Supply - Black
Phanteks Enthoo Pro M Midi Tower Case with Window - Black
MSI NVIDIA GTX 970 Graphics Card (4GB, 1076MHz, 256 Bit, DDR5, HDMI, PCI-E)
Kind Regards
