Video Problem
22 Oct 2006
Scotland
I dont really know how to describe this problem in one or two words, hence the title.
But when I restarted my PC after installing some program, my resoulution has messed up, I use a widescreen TFT, I use 1440x900 but I cant select it, and it has reverted back to 1024x800, I launched a game (CSS) and to my joy I had found out that my game resolution has messed up too, in that, I can no longer select 1440x900 anymore, even in the 16:10 resolution drop down.
I havent updated any drivers that would have caused this or anything, that I can think of.
simulatorman said:
Try Uninstalling video drivers and reload them...
Ok, what is a good program to uninstall drivers? If I look myself I will end up getting useless tat, I dont want to harm my system.
Uninstall from your Control Panel, reboot into safe mode, use Driver Cleaner Pro to remove any last files, reboot and install drivers fresh. :)
Driver Cleaner Pro can be downloaded from www.guru3d.com
Right, ive done that, removed the drivers, then restarted used driver cleaner, restarted, installed them again, and restarted, which was quicker than its sounds.
But still no luck, I really need my native resolution back :( :(
