Hi. A couple of weeks ago I decided that I wanted to try and record some CS:GO gameplay using dxtory(I've considered other programs but this one in particular seems to have one of the best recording qualitys using the lagarith lossless codec which makes the videos take up a lot of HDD space but the quality is flawless).
Now since I intend to edit said videos and render them later on the file size isn't an issue to me the problem is sometimes altough I'm not lagging ingame(sometimes I do but only slightly hardly noticeable) but the video I recorded has some lag. In some parts none in other parts nothing major and sometimes it's rly laggy.
These are my computer specs:
Win7 Ultimate SP1
AMD FX-6200 (overclocked to 4.7ghz)
AMD 990FX
4x Kingston HyperX KHX1600C9D3/4GX (total of 16 GB)
Sapphire HD 7970 Vapor-X
Asus ML248 [24" LCD]
And then I got 3 HDD 1 external of 3TB USB 3.0 from iomega(not the best when you are trying to write data I just use it for storing media), an SSD OCZ-AGILITY3 ATA Device (SATA-III) and a 1TB WD Sata II internal HDD which is where I'm trying to write the data on because I believe it's the most apropriate(the SSD isn't full but it's only 120GBs and if I happen to want to record for 1 hour in lagarith lossless codec the filesize will surely be over 200GBs.
Now I've got a couple of questions and I apologise for the long post but I'm just trying to let you in on everything.
First of all I think that my computer specs should sufice to record CS:GO in 1080p(some of the settings aren't even at maximum) anyways if you think otherwise please let me know and let me know what should I improve(I do know my cpu right now is the weakest element on my computer).
Second of all if my computer is able to handle said task then what is wrong and what can I change for example changing Video card configuration. I actualy got 1 question regarding that. I've never messed with the pixel format (YCbCr 4:4:4;YCbCr 4:2:2;RGB(limited) 4:4:4;RGB 4:4:4) now I do know is related with color my question is I've been using YCbCr 4:4:4 since forever but will any of the others improve my fps or anything that can help me record?
As for Dxtory settings in the movie tab I've set video codec to lagarith lossless codec; Framerates 29,97(I searched the web for a while and saw a lot of people saying it was better than a static 30 fps because it would decrease lag and I tested it myself and noticed some improvement with that);File Output "Check";File Format AVI And scaling 100% and all the remaining settings on movie tab are either unchecked or set to default(0)
Then the only other setting that I changed was in the advanced tab where I set Processing Threads to 6. Nothing else that seems related to the video itself.
Now I'm not putting my CS:GO settings here just because I know there are very few people that play it right now so I don't think it will help you helping me solving whatever the problem is but if you think otherwise I will be happy to put them here as well.
Thank you for your time.
Here's some useful information and hardware performance:
http://img703.imageshack.us/img703/2...erformance.jpg
Win7 Ultimate SP1
AMD 990FX
ty
