Hi,
Got a Compro Videomate K100 today.
The drivers etc. installing perfectly for Vista and it controls everything almost properly.
Basically if I press a button more than one in a row (e.g. the arrow buttons, or the volume up/down button) the second press doesn't register.
So lets say I have a row of 10 films, to navigate across them I'd need to press the arrow, then another button, then press the arrow, then another button etc. The only way I can get it to register multiple button presses is by holding the button down, but then it just flies across the screen which makes it very difficult to select a film.
The same goes for volume up/down, if I want to turn it down e.g. 5 'notches' I'd have to press volume down, then another button, volume down, then another button etc. I can hold the button down, but then it goes from full volume to no volume within a second.
Not sure if it's a problem, but on the little VideoMate icon it says 'no device' even though the remote is half working...
Every button press is registered, the light on the remote flashes at the same time as the receiver every single time.
I have tried in my brothers PC and it does the same thing, I'm also extremely close to the receiver at the moment so it's not that.
Is this a known problem, can it be fixed?
Thanks,
Craig.
Thanks,
Craig.
