view fat16 partition in XP or Vista?
29 Oct 2002
London
I have a 257MB hard drive from and old IBM machine which a colleague wants some data off. when i put it into XP and try to view it it wont initialise the drive - is this due to it having a FAT 16 partition do you think?
no it initialises fine, just as any other hard drive, connected via usb caddy, would but it wont show anywhere excet in disk management whereupon it is displayed as uninitialised - attempting to do so does nothing and attempting to assigna drive letters doesnt work.
i have used east recovery software to get the data off but, as anyone that knows recovery software will tell you, the retrieved data is a bit messy.
ahh well it may well be that i have gotten as far as i can with it :)
